add an amp. RFs?
To do it you will need an amp that will take speaker level inputs..Tap the speaker leads from the rear speakers and run the tap to the amp. If you can find the remote turn on for the factory amp or the power antenna lead and tap that as well..You will need a relay for the remote though it may cause too much pull from the deck and can cause problems.. I am doing something similar with a friends 2001 Grand AM with the Monsoon system..He decided to skip the relay so we wired in a toggle in an out of the way location.
Mike
steagan
steagan
omaha, ne
mykeys
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
