Active with new Rainbow/Alpine setup?
Lucid15
Always open to trades!
I got the following setup on the way or already here:
HU: Alpine-CDE-HD149BT: http://www.sonicelectronix.com/item_...E-HD149BT.html
Comp Speakers: Rainbow SLC 265 Kick: http://www.woofersetc.com/p-7032-slc...nt-system.aspx
5-Channel Amp: Alpine PDX-5: Birth sheet reads 105w x 4 RMS and 360w x 1 RMS http://www.crutchfield.com/S-Mjx7l32...ine-PDX-5.html
Subwoofer: Rainbow Profi 10": http://www.woofersetc.com/p-7122-10-...subwoofer.aspx
Amp Install Kit: KnuKonceptz 4 Gauge : http://www.knukonceptz.com/productDe...?prodID=KCA-K4
My question is i can go active with this setup correct? I was thinking i could wire each comp speaker to the amp run 3 pairs of RCAs front, rear, subwoofer active. And then possibly run the rears off my HU? It seems like this should work and sound pretty darn good as well. The PDX-5 seems like a very easy amp to set my crossovers up and get the most out of the kickbass comps.
Thoughts?
Thanks for the input. I figured i should just trust that the passive xovers by Rainbow are probably pretty quality anyway. I'll start a new Build Log Thread when i start putting this thing in and keep you guys updated on how it sounds. Really stoked to hear this equipment together
10
516
10
944
https://www.alpine-usa.com/products/subwoofers/truck-enclosures
As for your setup, the circled input in that reply is where the LOC (built into the amp) is located. You don’t need a LOC other than that. All you...
35
4K
well they list that frequence response so I will try to use it. Also, does it help to have the marine speakers in their towers for such a thing...
770
Lucid15
Lucid15
Portland,OR
Lucid15
    May 12, 2024
Brendon Jenness
    May 11, 2024
