active question guys!!!
maloy013
just bought an alpine pxa h701 and m ready to go full active:crazy: //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif just wanna know if still have to use the crossovers in my amp or just bypass it and go full range and let my 701 do the work??? thanks btw ill my comps are pg rsd 6.5s:D
ok thanks first timer here //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif can u tell me what settings u have if ur running active?
btw i think we have have the same car(if u drive a scion tc) //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
you have a scion tc and are running the rsd's? i have a tc running rsd's active. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif ask me whatever you want. i'll have all the info you need.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i have my sub at 63hz/18db, mids playing from 80hz/18db to 2k/24db, tweeters are playing from 2.5k/24db and up.
where did you mount your tweeters? have pics of your install that i can see? just curious since we have the same car.
tcguy i understand the sub and tweeter settings but the mids??? is that bandpass? how u do that? btw i havent installed my 701 yet just wana get some info before i do
yea, you will be band-passing the mids. the h701 will allow it.
the stock location is ok for the tweets but they will be better down in the kick-panels. you could try them where they are and see how it goes but if they sound harsh or bright it's because of the location.
the stock spot for the mids in the TC is actually not bad at all. just deaden and seal your doors and you'll be set as far as that goes.
here ya go guys
if its like the active processor that was on my 9855 itll have option for mid/high mid/low.
maloy013
maloy013
clifton, nj
maloy013
NorthFramingham
    Jun 30, 2026
