Accord XM/CD Changer help
RMD122
I have an 01 Accord that I want to add XM with the SkyFi unit. I have the factory single disc receiver with the factory (dealer add-on)6CD changer mounted directly beneath it. The problem is I want to use the receiver's CD input for XM so I don't need a modulator. This will disconnect the 6CD changer which of course I don't want to do.
Does anyone know a way to hook up BOTH the factory 6CD changer and XM at the same time?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
hi if you want two changers in your car then try getting one FM Cd Changer and you can hook up ur xm changer too. or you will have to shift the brand try using kenwood they have this option of hooking up 2 changers with one head unit or if you want loads of audio kenwood has the mp3 changer wihich works with alot of kenwood new head units. Best of luck
RMD122
RMD122
Naples, FL
Teffi
vegang
vegang
