Accord and alike guys. Enter!
Ahhm see, theres the bad part about living here, as far as fuel goes. I live in north eastern Kentucky, where its always up and down hills no matter where you go, theres always a grade of some sort. a little extra power from a v6 would actually probably raise my mpg's, since more power would mean I wouldnt "struggle" up hills, but instead climb up easier..if you see where Im coming from? But Im fine with what Im getting //content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
try slipping it into neutral while coasting down hill - you'll see the RPM's drop to below 1k during that time, saving you gas. it can almost make up for the gas you use going up hill. the honda's and toyota's i've owned had no problem doing this on a regular basis - the auto tranny can slip between N and D with ease - and won't slip into R unless you press the button. just don't forget you're in neutral, and hit the gas, up the rev's, then slip back in gear - that would be bad. only put in gear when RPM is below 1k. inevitabely you'll forget, hit the gas, hear the rev's - then you must wait until the engine calms down before you slip back in gear.
a 4cyl will use less gas than a 6cyl in almost every case, even uphill. even though the revs on a 6cyl may be lower, you have 150% fuel usage at all times. my VVT-i4 2002 camry is almost as peppy as my accord and it is our travelling car. no problem going up hills fully loaded with the family. that said, i hit 6k RPM on my Accord very often and it does so effortlessly, the Camry seems to not like that as much. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
896
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
790
I don't think OP is going to do the deadener themself, but these are my tools for it. If its 80 degrees out, you can just leave it out and it's...
Based on the age of your system, it may be a good idea to look for a new aftermarket unit.
fannin88
fannin88
ky
keep_hope_alive
    May 16, 2024
    May 16, 2024
