AC went out :(
see my heater works so idk if that has anything to do with it, When i turn the cold on it works its just not cold its kinda hot depends on how it feels outside..
maybe it's low. open the hood and see of the compressor stays on constantly with the a/c on. the little bracket looking things should spin with the a/c on. if they stop you are low on freon
first things first, check to make sure the compressor is at least running, ie no belt problems and you should see the clutch engaging on the pulley, and the thing is the way to really be checking is to be feeling some of the lines, certain ones will feel cold certain hot, theres the compressor, evap, a metering device of some kind and theres really no way to just say the a/c is out and something in particular is bad, like there could be frost on a liquid line maybe or is the condenser sweating theres a lot of various conditions
the refridgerant is R134a and dont buy those **** little cans from wal-mart or k-mart or something, actually take it in for a proper evac and recharge unless you know someone with a recovery machine but i really think it needs to head to a reputable shop for further and proper diagnosis.
what's wrong with the cans from walmart? IF it is low fill it, but i agree there could be many problems. also be carefull touching a/c lines cause the hot is one is hot and will burn you.
Jordantyler
Jordantyler
arkansas
bimma85
