? about stock GM comps and replacing
  • 2
cdr
AZ
I have a 99 c/k chevy 2500 and it has a 6.5" mid and a 1" tweeter in doors both are running 4ohms from headunit or so I think and the tweeter has a capacator on it as a crossover.
My question is concerning how GM splits these signals is there as I am going to be putting a set of Cadence ZX651 coaxial speakers in which I would like to run off stock wiring from head unit (will be amping these speakers down the line). So is the wiring to stock mid full frequency from the head unit? And if so what how do they splice the tweeter in wouldnt this disrupt the ohm load? And if its not a full frequency signal to the mids where can I patch in pre-crossover(or whatever they are using)?
thanks a bunch
I hate to press a matter like this, so forgive me.
But I need to resolve this issue before I go back to the wholesaler tomorrow afternoon. As I have on my hands one set of 6.5" coax's and some speaker adapters to fit the gm mounts.
any help or adviced greatly appreciated, thank you
Yes..you will get full signal. The cap for the tweeter filters the sound. You can leave the tweeter in as well. you should see no problems replacing it.
ya I was thinking about this last night and I said dope Im an idiot //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks for the reply
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
218
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
534
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
344
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
547
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
cdr
cdr
AZ
cdr
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
