? about KOLE AUDIO
9515ROB
TEAM DTF
im looking at the KOLE AUDIO TRAX1-6=7000D and i was wondering if any 1 has ever used cole audio and if so how they hold up and if they do the power they say the put out. If some 1 could let me know it would be a big help
i will be put n this amp on a DD 9515G Dual 2 ohm
ight thanks u guys what do u think about the SPL FX1-5500D
or if thats junk to then what amp is some what cheaper that will be able to put at least 3200rms at 2ohm and 4000 at 1 ohm
i like this fourm so much more than my other 1 i use i get my ? answered quickly which means alot when ur try n to figure out what u need to buy
Also, junk.
What is your budget?
Also, junk.
right now i got a POS Quantium 4000 mono block im try n to sell 4 $300 and i was going to get my MA AUDIO HK4000D fixed but that was going to cost me like 450 and i figured that if i can find another amp new or the same size 4 a lil more or less then i will get that the most i wanna spend right now is 600
but i also dont plan on having this amp 4 ever bc im tring to save up to get a DDZ2LV but i got a long way to go till i get that so i need a amp that will last at least 2 years. I want something that will give that sub plunty of power for daily and when i need to go to comps i can give that sub all the amp will give it.
so any opions are welcome
4k@1ohm for $600 is a little hard. If your are willing to buy used there are a few deals you can find. There is a Hifonics XX Cyclops for sale here for $700 shipped. If you are willing to take a lower power amp then a sundown 3500d would be a good option (or a used 3000d)
Those can be had for 600+. db-r sells them new and re-furb. or you can get a used one from this forum here.
The amps you mentioned would get the job done cheaply. But, they only give about half of rated rms. I use a bamf series amp from power acoustik. It really only does mid 2k@1ohm. They publish 3200@1ohm. (kole and pa use the same boards from what I have heard).
Also, junk.
Listen to the man... he's got a nearly identical amp in his sig.
Since you run a DD 9515, I think you should go for something halfway proper. I'm all about value (watts/$$), but don't smoke a DD with a crappy amp.
2kw is enough for that sub, but 3kw is beautiful.
a couple options:
Hifonics XXV Colossus. Bridge it and get 2200wRMS @ 4 ohm. Reliable and strong.
Audiopipe ap30001d - ~$350 and does 3kw @ 1 ohm
Sundown saz-3000d
List goes on...
a couple options:
Sundown saz-3000d
List goes on...
Maybe you should have read my next post then. What a surprise we suggested the same thing. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I was drooling over that Cyclops earlier... but it'd melt his 9515 unless he's doing SPL burps.
At 4kw, I'm sure his ears are begging for only short burps too. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
im thinking about getting a audioque 3500D... how do u think it will do on stock for a little till i get a couple batterys and a new alt
what kind of watts do u think it will put out
9515ROB
TEAM DTF
9515ROB
Sherman IL
9515ROB
