? about fiberglass pods
brmcm15
Oh lawdy!
i know how to make the skeleton and do almost everything after that,
but i dont understand how to attach the pod to the door after its finished??
do i drill the the fiberglass enclosure to the door??
i dunno thats the only part i dont get
help understanding this would be appreciated
There are many options and is install dependent. If you were to screw them in you would probably want to go from door to pod. You could also fiberglass some bolts into the back of the pods and drill holes in the door and use washers and nuts to secure them.
Hey I'm just getting into making pods and want to make sure I understand completely as well. Do you lay first base coat(s) of resin down, drill holes through it and the door panel, attach a bolt and washer, then fiberglass over the bolt head and washer so it is permanently attached that way? Or do you complete the pods and then drill holes and insert bolts/washers? I'm leaning towards the first of the 2 options to make them a permanent bolt, just wanted to clarify before proceeding. Thanks in advance!
brmcm15
Oh lawdy!
brmcm15
Macomb, Michigan
blister64
