A New Record!!!
RangerMan
Premium Member
Premium Member
Today, while doing an install, I ran across a problem...I blew 4 **** 40 amp fuses in 10 minutes. I was installing a 1200.1 running a 9512 @ 1 ohm. My question is am I blowing the fuses from too much current or what...I have never run across this before. Hey, we all learn new things every day!!!
All help appreciated!!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
RM
Originally posted by RangerMan Today, while doing an install, I ran across a problem...I blew 4 **** 40 amp fuses in 10 minutes. I was installing a 1200.1 running a 9512 @ 1 ohm. My question is am I blowing the fuses from too much current or what...I have never run across this before. Hey, we all learn new things every day!!!
RM
1200.1 at one ohm will draw over 110A at full tilt.
You are extremely underfused. Make sure you are running adequate power wire also, 4ga minimum.
Thanks man...what does it pull at 2 ohms???
Originally posted by RangerMan Thanks man...what does it pull at 2 ohms???
Been stated to do about 113 amps at max... at 2 ohms.. it gets a little more pissy at 1 ohm and draws a little more (hence the reports of it heating up more often), expect around 130ish then...
RangerMan
Premium Member
Premium Member
RangerMan
NC
jlaine
michigan born
    May 14, 2026
michigan born
    May 14, 2026
