A few wiring questions.
Colt9699
Rockstar
Ok i have recently purchased a new amp and it has dual 4 ga inputs for power and ground.
Funds are limited so I got a length of 1/0 a distro block that has 1/0 in and 4 4ga outs also got a inline fuse holder with a 250a fuse...is this adequate for 1/0.
My question is do I have to do the same with the ground or is it ok to just run 2 4 ga wires right to my ground point and directly in to the amp with no distro block?
Also I am running 1/0 for the first time in my van and wanted to know is it ok to run the wire under the van say thru the frame rail or someplace under there?
A simple SEARCH would have answered that.... Depends on the length, 250-300+ you'll be fine.
Sure
It's only as good as you make it.... make sure it's protected from the elements
Colt9699
Rockstar
Colt9699
Erie Pa
Omarvelous
vegang
vegang
