a few questions on SPL enclosure
AScreenName
Custom User Text
485
somewhere
my friend who owns an RE 15 XXX wants to compete in the local SPL competition that comes around each summer, and possibly in other competitions in northern california if we can find any.
so i was thinking about what kind of box would be good to build for SPL
heres what i came up with:
a 10.13 cu ft enclosure, tuned to 44hz
the dimensions would be 20" high X 25" deep X 35" wide
we would make a slot port, and have the actual effective port area be outside of the box, kind of like a protrusion, so the vent doesn't displace any internal box volume and screw up the tuning frequency in the process.
i figured we would use the bottom of the widest side, and make the port area 33.5" (each .75" of MDF on each side displacing 1.5" from the 35" side) by 5". when i went to a site to calculate what the vent length would need to be, it said it would need to be 10.13" long. i was wondering if somone could check my calculations, approve of this idea, or possibly recommend a diffferent/easier plan?
thanks guys, appreciate it
Well, honestly....like tommy sed, doesn't need to be tht big! I mean, keep the port inside the box...make it like 7 cubes net. MORE MORE port area...like 100-150 sq. inches of port. Tune it like 56hz or so...should peak around 58-59. peace
NG
its going into the back of his jeep wrangler
i think i'll do a 6 or 7 cube box
should we really tune it that high? 55hz or so?
****, is it a hard to wrangler? hopefully so, because if it's a canvas top it's pretty much useless to compete SPL wise...even with hard top...check for leaks and **** around seams. And, yes, i'd tune it 50-53hz or so. peace
NG
I was thinking the same thing when i read the initial post. For SQ in a wrangler, your best bet is to downfire the box. Assuming its a hard top, your best bet will be upfiring with the sub on the same face as the port. If it's a canvas-top wrangler, your best bet for SPL will be to put your equipment in a different vehicle.
its a hard top
we might be able to borrow a friends like 2000 dollar thicker than hell hardtop for the comp. we were thinking maybe we could get some 2X4's to put from the floor to the top to reduce flex LOL. ghetto as hell.
so we should downfire the box?
Sorry...i just reread my own post and realized how confusing it sounded.
Downfiring boxes are for SQ purposes, not SPL.
You will probably want to up-fire the box for SPL. This means both port and subwoofer on the same face pointing toward the top of the cabin. You might also try rear-firing (both sub and port facing the back of the cabin). I'm sure they'll have a clinic at any event you go to so you'll have a chance to try both methods and see which works best for your vehicle.
i'm building a box for 2 AW1200Q's for competition and i called audiobahn and they told me the box should be 37-d, 41-w and 18-h=13.38 cu.ft. and a port of 100sq.in. and it should be tuned at 30-34 Hz with a spike at 34Hz and 7.4dB the meter is 97" from the box, can you guys tell me if this would be a good box for competition and what should be changed? It's will be in a 2000 Ford Expedition.
Thanks
Rob
Thanks
Rob
Way to bring back up a year old thread //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Could have started one yourself...about your personaly question //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
NG
Rob, first of all you need to find the resonant frequency of your 2000 Ford expedition and that will be the tuning freq of your port. 13.38 cubic feet sounds a bit big for 2 audiobahns but maybe some other CAF members can voice their opinion on it.
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
8
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
7
I found this, can it be done with snapon modis ultra scanner which i have...
11
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
579
AScreenName
Custom User Text
AScreenName
somewhere
pacho
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
