A couple of questions from a paranoid aftermarket stereo installer noob
  • 1
mail4youtoo
NH
Good Morning.
This will be my first post so please be gentle.
I have a 2007 Altima 2.5S with an OEM non-Bose stereo with manual climate controls. I will be installing a double-DIN Kenwood DDX371 headunit which I just bought from Crutchfield and should be arriving in a day or two.
Now the install kit that Crutchfield supplies ( scosche ) has that flat black look to it which I do not like at all. I am not sure if its the same with all their install kits. However i was able to find a dash plate from Nissan that will do the trick 2006-2008 Nissan Altima Navigation Installation Kit OEM
My first question is will I be able to use the rest of the Crutchfield supplied install kit with this Nissan plate on the front, or better yet as the plate is a Nissan part, would I be able to use the original metal parts from the OEM head unit already in the car?
Second question is general of the car itself. This is the first car I have owned that had a push button start. After I disconnect the neg cable from the battery do I need to do anything else electronically? Will I mess anything up with the push button start by disconnecting the battery? I am paranoid. I have read about the passenger-side airbag light and the process to reset it if needed but I am worried about any potential to mess anything else up.
My last question is really just advice. This new head unit has a rear USB connection in which I will be adding the USB extension cable included with the kit. Where would you advise I route the cable so that I can access it easily? I was thinking of drilling a hole into the little cubby under the climate controls where the DC plug is located. Is there any issue in doing this? I want to be able to plug in USB flash sticks with music on them or be able to plug in my iphone when I need without having to dig around for a cable. I had thought about running the cable to the glove box as a second option but I have a lot of crap in there.
Thank you for your time
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
The SIA is a great line of amps. People like to hate. My little SIA does work with 4-8's. And it bangs the lows.
23
7K
Yea. I literally spent 2 hours perusing the site. Got to love a helpful website. I bet that they have thought of everything that could possibly...
925
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
mail4youtoo
mail4youtoo
NH
mail4youtoo
Brendon Jenness
    May 8, 2024
    May 8, 2024
