99 Miata, so sound!
bibby
My friend bought a 99 miata with the bose package. It has a cd deck, and a tape deck stacked on top of each other. I pulled the top (cd) deck out, and put a reverse wiring harness in, and wired the deck up. It has power, and you can play with the settings and all, but no sound. It's an older deck, so we thought that was the problem. We went and bought a brand new deck, same problem. I am thinking that somehow the lower (tape) deck is causing it to not play somehow. Anyone have any experience with this, or any ideas?
Bose systems have factory amps... they're a bish to work with. Your best bet is just rewiring the h/u straight to the speakers, because bose is a PITA to work with.
geh. I'd really rather not go that route, any other way?
In a lot of chevys with bose you can conect the amp wire to the blue wire in the harness and make it work...I'm glad my Miata didn't have that crap in it
That makes sence. I will try that first. Any other ideas?
here's an idea,
take our advice, run new speaker wires, it is the proper way to do it. You will need to measure the impedance of the speakers and make sure they are 4 ohm, if not (which most bose aren't) then you will want to replace the speakers while you are at it.
here's an idea,
I am actually. I was just trying to verify that there are no more options. Thanks for the suggestion though! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
bibby
bibby
none
azbass
