'99 Cobra 'Vert Single 10" ported box build-up *PICS*
VereChronicus
Not much else to say, customer comes over with a '99 Cobra Convertible and wants as much slam as he can get and still be able to use SOME trunk space. Well we all know how narrow the opening is on those trunks. 9" deep if you want to make the enclosure as wide as possible. O.D's are 12"H x 9"D x 38"W. After port and braces we have 1.45^ft3 of net volume tuned to 45Hz with a 22sq" vent. He has a 6 channel Alphasonik that has a pretty weak 5/6 channels bridged to go on his 1010a sub. He'll enjoy it though. Enjoy.
Here is a pic of the baffle/port assembly with braces.
Another view.
Yet another.
Bottom and a side.
Bottom, both sides and back assembled.
Pics of baffle set in place, not glued or fastened.....
Waiting on glue joints to dry for painting inside of vent, will post the rest after it is finished.
VC
Otay, here they are.
Spreading glue on baffle/port assembly.
Angle view.
On her back, topless and beautiful!
Close up of bracing.
Front to rear brace installed.
A look at the butt joint braces on the rear top and bottom, can't see the front two.
In the middle of carpeting.
Uh, still in the middle of carpeting?
Hmm.......without looking at the ends, can you see the joint seam in the carpet?
Front with sub hole cut out and carpet wrapped into the hole.
Finished enclosure ready for the sub that'll go in it tomorrow and it's home in the back of the Snake.
That'll fit any mustang from 1979 and up, it'll fit in the glove compartment of most everything else. j/k but those convertibles really leave much to be desired.
VereChronicus
VereChronicus
Estados Unidos
VereChronicus
