Tonyguy
Welcome to Thunderdome
Even the 9833 would do great, as it is the same as the 9835 but w/o the display. It works in my setup and the time-alignment is sweet.
how are you planning to bandpass the midbass if you are going to share the output w/ the sub? or yea a clarion drz9255 might be a good option. but h701 would be even better //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.1 mono, 1 4channel, 1 4 channel bridged to 2 channels.
I was figuring on :
substage: 500hz and below (sub:0-60, 8s: 60-500)
mids:500-3/4k
tweets: 3/4k and up
he can use the amplifier's hp/lp x-over to split midrange and midbass.how are you planning to bandpass the midbass if you are going to share the output w/ the sub? or yea a clarion drz9255 might be a good option. but h701 would be even better //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
he's planning to split the sub rca output between the sub and the 8. in which i guess you can set the low pass on your hu as high as you can (but most hu's cannot lowpass the sub output at 500hz, more likely 200hz) then set the high pass on your midbass amp to 60hz and then set the lowpass on your sub amp at 60hz. but it all depends if the hu can set the lowpass on the sub output at around 500hz, which most hu's don't.he can use the amplifier's hp/lp x-over to split midrange and midbass.
beat me to it,
that's what i did before i got the h701.
