97' Maxima stock wiring???
BAD_MAYHEM
97' Nissan Maxima NON Bose
Bought new polk coax's for my rear deck.. Have no clue of the polarity of the stock wiring.. No markings on stock speakers at all.. Anyone have an idea??
RR = Green wire Red wire
LR = Blue wire Pink wire
Thank you VERY much to anyone who can help me out here...
easy.
note how you had your old speakers hooked up. Take a 9volt battery and touch it to the terminals on your old speakers. when the cone pushes out, that is the correct polarity. So which ever wire was attached to the speaker terminal that the + was touching when you applied the battery and the cone pushed out, is your + side.
Yea I was going to try that but I through em in the garbage...//content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
Thats why I need a wiring diagram...
When you wire them up just listen. If they are wired out of phase you will hear no bass from them. I'd fade to the rear, and get the new ones to work right, then make sure they are in phase with the front speakers.
Thanks for your help all.. I'm just gonna run em off an amp.. My HU just doesn't have enough juice to make these sound good and since I gotta run the front comps off an amp I might as well do it right...
BAD_MAYHEM
BAD_MAYHEM
Las Vegas
BAD_MAYHEM
