96 GMC Ext cab build
Thanks brother ... You have your mids and highs in stock locations ??
Ya But I screwed up when i installed them I didnt think the mids would clear the doors windows so i put spacers under them and cut the round tube like projections off the back of door panels so they would clear and they still wouldnt allow door panels to clip back down tight . Then I found that they would clear without the spacers so now i have to figure out a way to seal them back to the door panels so all the sound is not trapped between the doors and the panels. I have another set of door panels but vinyl in crap so maybe cut off the bottom plastics where thy seem together and somehow put them back on mine originals ? any ideas ?
I responded to your question on MAF ... with pics
Ok Great ! and thanks
If I can ask one more question ? I am going to order some 6.5 mdf rings to build out to the door panel and looks like you used 3 on each door , are 3/4 or 1/2 thick ? looks like 3/4 but i am not sure.
Thanks again
Thanks again
Wow thats great and I bet they sound good to huh ?
If I can ask two more questions ? I am going to order some 6.5 mdf rings to build out to the door panel and looks like you used 3 on each door , are 3/4 or 1/2 thick ? looks like 3/4 but i am not sure. And is the MDF coming thru the door panel or sanwiched between mdf and grill ?
Thanks again
Yep ... I'm constantly working on my ole truck ...
Thanks again
Thanks again
ChaseinBass
ChaseinBass
Calif
ChaseinBass
