'95 4 Door Tahoe Fiberglassed Amprack (Pics)
DOHCrazy
Monday I started work on my amprack. Its under the rear seats, and will hold a nine.1, nine.4, and two distrobution blocks.
This was my first fiberglass project ever. I had never even watched anyone in real life do it, only the GMC.com videos. I learned alot, and could probably do a better job if I redid it, but it works, and will look nice once carpeted. Since it was only an amp rack, the few mishaps I had are only cosmetical and will be covered up anyways.
There are T-Nuts glued in on the underside of the plywood for the amps and distro blocks. I plan on doing alot of installing and uninstalling whiel doing my wiring so this was a good choice.
Im going to be doing my kickpanels before school starts, and think they will come out nicely because of the past two days experience.
Getting to the pics, resized, as Im not as incompetant as most picture posters. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
The work area:
Masking:
Matte on (This was my first mistake, I should have worked peice by peice):
Resin:
Mold Out:
First Trim:
Final Trim:
Mounting Plane:
Dowel Rods:
Top Mounted:
Test Fit:
Gromets:
Fleecing:
Redid fleece, Resin:
Matte Applied:
Trimed and tested:
Under amp holes cut and inside reinforced. Hole for seat bolt:
Carpet will be here on friday, I will update with pictures.
Thats what I was thinking, but to get it flush to the floor it is kinda needed, not to mention its good practice for bigger fiberglass projects he might want to do sometime.
The reason I glassed was so it fit snug, didnt move, and I could use the factory seat bolts to secure them rack.
Also for practice //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
looks good. nice and clean //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
should be good practice so you can do something nice with your doors //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif;)
and stop taking sideways pics
DOHCrazy
DOHCrazy
Dallas, TX
req
