93 deville couple of questions
  • 2
Cc93d
Ok have ssingle sa x12 d4 says 1250 rms. Got hifonics Brutus 4000.1 says it does 2000 rms at 2 ohm. My alt does 140 amp. Door speakers pull 1200 watts haven't got an amp for them yet. But before I spend more money. What are my power concerns?
best approach is to invest in a cig lighter voltmeter and monitor voltage after you install.   if the voltage drops below 13.5V while driving then the alt cannot keep up and you need to consider some upgrades to the wiring and maybe components.
Door speakers don't "pull" wattage.  speakers present an impedance load that the amplifer is trying to drive.  as input signal (audio/RCA) increases, the voltage out of the amp increases.  as voltage increases the current out of the amp increases.  wattage delivered to speakers/subs from the amp(s) depends on the volume level.  music is fairly dynamic and has a pretty low signal for most of the time.
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
The SIA is a great line of amps. People like to hate. My little SIA does work with 4-8's. And it bangs the lows.
23
7K
Yea. I literally spent 2 hours perusing the site. Got to love a helpful website. I bet that they have thought of everything that could possibly...
921
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Cc93d
Cc93d
keep_hope_alive
Brendon Jenness
    May 8, 2024
    May 8, 2024
