90-93 Accord question
It's really dependent on how big the opening of your trunk is. Most sedans have maybe about 17-20'' of vertical trunk space, so a 15 will be tight, but doable, the problem is actually sliding the box into your trunk.
Just measure, and build a mock-up out of cardboard to see if it'll fit.
I'm in the process of puttinga 15'' Q in my trunk in a L-port box, exactly how you described. I have a '98 Oldsmobile Intrigue, 4-door, with about 18'' of vertical trunk space. Luckily I have a huge opening to my trunk, so I should be good.
i've had a ed e15a in a 2.2cf vented box, i had a SI Mag 15 in a 3.7cf vented box and now i have two 15 Mags in a 5.2cf sealed box. I however have the 1992 2 door. but either way theres plenty of room in the trunk for a 15 ported.
edit: all boxes were made in my friends shop, not in the trunk
Most people have a lot more room than they think, it's just a matter of figuring out how to use it. Like I said, measure and measure again, then make some carboard cutouts to make sure you measured right. You could even put an 18'' in there, you'de probably have to fire it up, or angle the front of the box, but it woun't be too difficult.
90accordman
90accordman
Fresno, CA
90accordman
