9.9/10 Mint Digital Design M3A 3k+ Great condition
Silverado SS
Shake Pound and Rattle
DD M3A
This amp is a beast, does 3k+ at 14 @ 1 ohm and 3600+ @ .5 ohm and is very underated just look up any clamp test for these amps. I have all the OEM items like the box, manuals, bass knob, from what I have seen DD`s Clip indicator on the knob is pretty darn accurate. Is .5 ohm stable and can be ran at .35 or .25 ohm for burps. Item is almost mint it has 2 tiny marks on top, I can try to get a pic for serious buyers but they are very very small like the tip of a screw and can not be seen unless you have a flash of some type and know where it is. Trust me when you take it out of the box you will not see it for a while.
Clamp test - DD m3 bench test results? - Car Audio Classifieds, http://www.caraudio.com/forums/amplifiers/515962-digital-designs-m3a-actual-power-output.html
Here are the specs keep in mind they are HIGHLY under rated and @ 11.9 volts
Bridged NA
Channels 1
Cont Power at 1 Ohm 2400W x 1 @ 12v
Cont Power at 2 Ohm NA
Cont Power at 4 Ohm NA
Damping Factor NA
Dimensions (Metric) 546.1L x 232W x 63.5H
Dynamic Power 4000W x 1ch
Efficiency Thru Output 87%
Input Sensitivity 0.15V - 5V
Shipping Weight 21 lbs
S/N Ratio >100dB
Tested THD ≥1%
Tested Voltage 12v -14v
Variable Bass Boost 0-6dB @ 45Hz
Variable High Pass Filter NA
Variable Low Pass Filter 20Hz - 200Hz @ 24dB/Oct
SOLD
on me to lower 48
View attachment 26541515View attachment 26541516
revamped crossover on the m3b's... not sure if that's all they changed though...
Power-wise, they seem pretty close - will know more this weekend. =)
Low ball city around here, you will never find this amp for 350, yes I was offered that 2 times unless its beat to hell. Price was 525$ its 500firm as iI said which is still a deal. Best 3k on the site and the best deal
Silverado SS
Silverado SS
Cleveland
Jamesfrogman
