8ohm plate amp needed
solidcrowd
I am guessing you are saying that they are all single 2 right?
If so you could wire them two in parallel and put that in series with the other two in parallel which would give you 2 ohms. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Crown stereo amp, built two Sonotubes and have stereo subbass //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I like the stereo part...
But would change the amplifier... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ehh probably under $150, going back to pe to check out what they have a 2ohms, since all I was looking for was an 8ohm amp, o and by the way is this diagram i made right?
More like this...
What you are doing is running everything in parallel. Which makes the impedance .5 ohms.
What you should do is put the pairs of drivers in parallel, which gives you 1 ohms each. Then series the two pairs giving you 2 ohms final.
solidcrowd
solidcrowd
Buffalo, New York
Fast1one
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
