8ga wire for subs?
5.7RAM
IL
Good,bad? I bought my type r used and figured I would open up the box and see how it was wired...well. I found 10gauge wire connecting the two VC's and 16ga to the terminal on the box. I wasnt too happy with this so I decided to take a trip to the the local sound shop to get some new wires. I ended up getting some 8gauge power wire for only .50$ a foot and put that in there. There was a noticable change. The sub seemed to "flex" more...(not sure what to call it when the cone goes in and out when the bass hits). Overall I was happy with it but wondering if it would have a negative effect on the sub? Doesnt seem like overkill since 8ga is prety small but just wondering.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
type r's are iffy. i have ran 8 gauge to them but in a friends install the weight of the wire (he had 8ga also) kept pulling them out. the easiest way is to run 4 10 or 12ga wires to the sub and dont use the jumpers. i have also seen problems with the jumpers staying in.
What do you mean by jumper??
With some help from CA.com ive decided to throw like 8-1000wrms at the typeR so should i keep the 8awg in?
12 awg is more then enough.
x2 its such short runs of wire he could get away with even 14 im sure without a difference. but I would have left what was in the box unless it was some el cheapo with thick insulation and was smaller then 12 guage
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
345
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
807
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
821
5.7RAM
5.7RAM
IL
Ilikeitloud23
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
