did anyone else pick up on the fact that this is a Class A/B amp????I wish it would put out rated power! shit, even half its rated power and I'd buy a couple! 360 amps worth of fuse but...
BRAND NEW Brand X XXLDB8000D 8020 Watt Mono Block Digital Class D Amplifier with Wired Bass Remote Control
3297 Watts X 1 Channel @ 4 Ohm
5997 Watts X 1 Channel @ 2 Ohm
8020 Watts X 1 Channel @ 1 Ohm
Low Pass Crossover: 40Hz-400Hz @ 24db
Subsonic Filter 10Hz-50hz @ 24dB
Variable Bass Boost @ 45Hz: 18dB
Discrete Class AB MOSFET Mobile Audio Amplifier
Top Mounted Fully Adjustable Linkwitz Riley Crossover Network
Full Range Pass Thru Line Outputs
0/4 Gauge Billet Style Machined High Current Power & Speaker Terminal Block
High Quality Surface Mount RCA Inputs & RCA Outputs
Heavy Duty Power Aluminum Heat sink
Power & Protection LED Indicators
Soft Turn-on/Turn-off
Fuses: 2 x 180 Amp ANL External
Dimensions: 11.57''W x 2.71''H x 29.21''L
^^^this3297 Watts X 1 Channel @ 4 Ohm5997 Watts X 1 Channel @ 2 Ohm
because its a a/b that claims 8000 watts. lolz!!!!!!!!!!How does it being an a/b make it a piece of shit.
why thank you pawn man for teachin teh n00bs round here teh bizniss. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gifif it really put out 8000 watts rms & was ab class it would be 10ft. long,weigh 200 pounds, & draw 1500 amps of current.
