8 guage wiring kit/kx-650.4
This is my first installation, please bear with me. Bridge 2 channels per coil meaning I would connect the sub via neg/pos parallel to the rear and my two kick panel speakers to the front? Anyway, thank you for the recommendation.
By two channels per coil, he meant if you were going to use channel 1&2 for one coil, and channel 3&4 for the other coil on the subwoofer but that's not what youre doing.
You have it figured out.
Ok, so 2 ch are already occupied?
To run your dvc 4 with the other 2 channels you're either going to have to wire the coils parallel for 2 ohms which will have the amp running at lower than specified stable impedance and could lead to overheating problems, or wire them in series for 8 ohms.
If you do the latter 8 ga would work, but 4 would still be the betterway to go.
matew1
matew1
santa cruz
n2audio
