75 watts @ 2 ohms..recommendation?
farmerehsan
144.6 db
Im looking for a set of speakers (mids and highs) 75 watts @ 2 ohms cuz thats what my JL audio amp puts out.
any speakers under $65 you kno about?
amps specs:
Rated Power (stereo): 45W RMS x 2 @ 4 ohm ; 75W RMS x 2 @ 2 ohm
Rated Power (bridged): 90W RMS x 1 @ 8 ohm ; 150W RMS x 1 @ 4 ohm
As a rule of thumb a +3dB increase in sound level requires a doubling in power.
It would be slightly louder with 75w over 45w, but in reality you probably wouldn't notice it until you jumped up to 150-200w.
I don't think you're going to be able to find 2 ohm components or even coaxials in the $60 range. You could always run two sets of 4 ohm coaxials in parallel which would present a 2 ohm load.
With the power you have available I'd concentrate on an efficient set of 4 ohm speakers.
E
E
Ok... I lied //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Did some research and there *are* some 2 ohm coaxials that can be had in the $60-$80 range.
6.5" coaxials:
- JBL GTO628
- Infinity Reference 6022si (shallow mount)
- JBL GTO638
- Infinity Kappa 62.9IS (shallow mount)
- JBL P662s (shallow mount)
- Infinity Kappa 652.9i
- Kenwood KFC-X1710
Similar models are available in 5.25" as well.
For 2 ohm components the closest to your price range is the JBL GT0607c which you can get for around $95 shipped.
Good luck!
E
farmerehsan
144.6 db
farmerehsan
Tampa
farmerehsan
