akheathen
Premium Member
trianoacitol contraceptiv
so, i guess the thread was succesfully hi-jacked.... nutthugger wins the troll award of the day, yay!
no, nor do i care to look it up, since i know it's low. i know they are they are weak, and no amount of research is going to change thatyou know the BL of the Sony or the Pioneer subwoofer in question? obviously not if it's part of your argument.
Of course not but we have a criteria in place. One that's pretty limited by low a power requirement. Most high BL drivers today also have a high moving mass coupled with very stiff suspensions. Both of which would be ideal for a small sealed enclosure (assuming this driver yields the expected low Qts), but not with 130 watts. He needs a low power, low moving mass, soft suspension driver that will be responsive to low power and doesn't cost very much. Pioneer and Sony have some pretty good offerings for that criteria. Remember, it's all relative.haha, yah, i suppose every sub is going to see it's vd no matter what you do with it, and they are all the same, huh?
These are not the same thing. And a 'weak' BL is not the whole picture. Do you know how to use the parameters to arrive at the true motor force? Do you realize that when you have a lower moving mass you can have a much lower BL and still come out ahead?relevence being, i found a way to get the junk off the shelf, without "technically" doing anything wrong.... your recomendation was the worst. vas and compliance aren't going to mean much when there is a real weak bl (it's going to have 2x the effect on what it's actually going to put out.....you know, the sensitivity/efficiency?)
And you can have a higher moving mass with the same BL to achieve a much lower Zmax at F3, therefor receiving 2-3x the power at the bottom end where the natural rolloff would have rendered it nearly inaudible with the other subwoofer with said higher BL? But "I" hijacked a thread.
For what it's worth (akheathen), I think you're pretty cool.....having some resilience is admirable.
Oh, now you're talking dirty. Impedance magnitude and power delivery on the phase angles and what not? Rawr....
so, it's an 8ohm sub?.... 2.83v is the 1w/1m setting for taking sensitivity readings on an 8ohm, not 4......Haha, 2m/1m. That's awesome. I think you missed where he said 2.83 volts @ 1 meter.
Indeed, very specialized full range breeds. He made a very strong point, though. I actually tried to make the same point, he just did a much better job of articulating it.nope, thought it was a typo....... are those house drivers?
