6 speakers one 4ch amp
  • 2
Can I safely run 2 6.5 co-ax, 2 4x6 infinity kappas which im near sure are close to 3ohm speakers alil under 3 actually and 2 infinity perfect 6.5 components 4ohm with crossover for tweet. All with a Soundstream Reference 920w amp.. specs on amp are 145x4 @4ohms, 215x4 @2ohms and 460x2 4ohm bridged? Thx Rob
If your worried about low impedance wire the two 3 ohm in series up to 6 ohms.
First I would wire the two 3 ohm speakers in parallel and check the resistance with a dmm.
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
7
137
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
79
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
930
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
314
thegnman
thegnman
Lewes De
SMS
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
