6 RE8 sealed, or 3 ported?
JeffyZ33
not******
So im getting 3 RE8s from a friend, and am planning on porting them. Then I started thinking about maybe 6 sealed.
Pro for 6 sealed
more cone area
should sound better sealed
more impressive having 6 then 3
Con for 6 sealed
need more rms
more room taken up
more $ on sub
Pro for 3 ported
Should have same output at 1/2 price
less rms
less $
lots of saved space
Con for 3 ported
wont sound as good as sealed
less cone area
less impressive then 6
Anybody have anything to add? Is it worth shelling out the extra $ for 6? Will 3 ported still sound good? I want good SQL for the winter. If they will sound nearly the same with maybe a little loss of SQ from the ported, then I will go that way.
Main question- Will i see a big loss in SQ from going with 3 ported compared to 6 sealed? Or is the difference worth the extra $ and space?
I think id stay 3 ported i dont think ull lose too much SQ but it will be loud........but if u got the money and dont mind the space those 6 re 8s woudl be pretty bad@ss....
how about 4 ported:) cause its much more impressive than 3:D actually, id probably just go with the 3 ported for the fact that you'll save a money will still achieving the output you want
Im not sure Id list 'need more room' as a con for the 6 sealed setup. The 3 ported will require a bigger box than sealed for each driver, usually about double, which would work out to about the same size enclosure. Figure in added volume for the port(s) and I definitely wouldnt just assume the 6-sealed setup would need the bigger box.
I think Id do the sealed system. The main difference in cost is the drivers, but these are relatively cheap drivers (but good ones, no offense heh). The sealed box would be a simpler one, and imo would look better when you fold the seat back to reveal twice as many cones.
For the 3, I would probably go with a PG Xenon series amp 500.1 (400rms at any ohm load). For 6, it would be a BX1500D.
What kind of output can I be looking at for 3 ported/6 sealed? The only thing I really have to compare to would be 2 12'' Comp VRs in 2.0cu ft ported boxes @35 or them sealed in 1cuft boxes.
A few questions
How much are these drivers
How much power at what ohm would you need to power 3
Would 3 8s be better than 2 12s?
1) I think they are 65 a piece. But do not quote me on that.
2) 3 could go down to 2 ohms. i would use about 500 rms to 800rms ( but of course this is totally box dependent.
3)NO But, that is just my opinion.
So then it should be 1.3 lol.
What kind of output can i realistically expect out of 6 8''s sealed? Maybe a 4cf box
Such as... greater then/less than
2x 12'' comp vr ported @35 700rms
1x 12'' p3 2cf ported @35 200rms
2x HE2 1cf sealed each @ 400rms
Now OBVIOUSLY there's a lot to do with the install, but i'm just looking for an estimate, because I really dont know what to expect.
JeffyZ33
not******
JeffyZ33
In A Tree
denim
