Lol I've posts online saying Skar is bad too but idk if because of the guy anyways so you would say their amps are good?
Sent from my SM-J700T1 using Tapatalk
Don't ask him...he doesn't know.
Some Skar amps/subs are ok but not all.
they the same as american bass and others, but no where near as good as the ts and wolfram.. bigblank here just tested the 2k did 2500, check out all his vids (subscribe he has sq 2250 coming up soon, u may like that) https://www.youtube.com/user/bigblank69/videos?disable_polymer=1
I know better than to misrepresent an amp...such as the Wolfram 4500 you recommended which you should have not opened your mouth about. There's a reason why I don't have Skar amps. Could I afford it? Of course but not the point here.
colin said it'll do 5100 (i did think more like 5500).. and my point was if the 2.8k does 4k in a dyno wouldn't it make since that a 4500 would do over 5k?
Won't that be too many watts going into those subs?
those subs need 1500 each min i would think.. most peeps run 2-3x rated power because of "box rise" basically whatever ohm load u at subs only get about the power of next higher ohm load so if 1ohm subs get 2ohm power.. and u adjust gain to power u want and don't over drive amp prevents clipping..
You did not know that UNTIL he mentioned it. Knock it off already....you don't know everything, but continue to run your mouth.
Lolhaha
Lolhaha
Los Angeles, CA
