Sold 5000 watts rms amp
tamagotchi
Banned
Hey your looking at a SAME AS Rd audio 5750.1 or ATOMIC 5000.1 amp this particular amp is the same as those mentioned above their the same in every single way except this amp has no logo the amp is like new except one single flaw.
the amp was used at burps at 0.5 ohms with a single amp i know im dumb and we blew the power supply output transformers ( FETS). They are probably IRFP064N -- that is generally what FET is used in the power supply on the TO-247 case. chris at db-r can definately fixed it i got an quoted at audiotekx 150 to fix it you can repair it locally if you know about a good shop the repair locally will be less than 100 bucks.
They sell for over $2000 retail and around $1500 at competitor cost! My price is $750 BUT this ones blown im asking 500 the 250 left will be for the repair cost.
specs
* Digital mono block amplifier
* Dual MOS-FET power supplies
* Efficiency over 86%
* RMS power handling---1500w @ 4 ohms @14.4V
* RMS power handling---3000w @ 2 ohms @14.4V
* RMS power handling---5000w @ 1 ohms @14.4V
* Signal-to-noise ratio 90dB
* Phase shift 0-180 degree
* subsonic filter: 10-60Hz
* lowpass filter: 35-300Hz
* Input sensitivity: 200mV -6V
* Bass remote controller with telephone wire & click volume & blue LED
* 3 way protection: over voltage, speaker short & thermal overload
* Total harmonic distortion:
* Continuously variable 0 – 18dB Bass Boost
* Built - in variable 0 – 18dB per octave x’over
* Power Consumption
* Size: 24.50” x 10.60” x 2.60”
they are bridgeable or linkable it was very dumb of myself run this with only one battery and stock alt everysingle person that really knows these amps recommend at least 2-3 extra batts with a good alt and u can run it all the way to 0.35 ohms at burps.
im located in chicago ill 60623 local picks ups always welcome pictures with name are welcome pm me for those kinds of pics, paypal ofcorse i will accept money orders only if the check has cleared i will ship, google check out too if you have problems with paypal,
this is a great offer.
PLZ dont post dump i will report post dumping to the admin WATCH THE RULEZ!!!
the internals pics are actual pics the parts i noted needs to be replaced you can fix it if you want but i suggest a profesional repair shop.
thanks
thanks
Oh lol you didn't get the memo we dont have an admin here.
those mosfets only cost about 2 bucks a piece if that is all thats wrong with it. So could be a cheap fix if somone is knows how to do it. But its doubtful that that is all thats wrong.
i now got 4 kx 2500.1 and gettin a mmats 3500.1 if i decide to repair it i will not get a secret sub i want //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
im a use a mmats 3500.1 daily on my 6 12s and im a use 4 kx2500.1 on a secret sub that i cant tell and i will get the charging right before i p ut everythign in //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yup my charging can only support 3500 rms not 5kw rms jeje thats why i blew it right now im rollign a zx2500.1 daily and the kx2500.1 are on the closet waiting for the sub
ur charging cant support 3.5k rms //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif i saw your electrical, stock alt, and thats it... thats why you blew it. sell me two more 2.5ks
tamagotchi
Banned
tamagotchi
chicago
R/T Pimp
