500 vs 750watts.
dpu2014
Im gettin two of the new 12inch SI mags. Would putting 750 to each of them be considerably louder then putting 500 to each. I would put 750 into both but I wanna save money and I dont wanna worry about an aftermarket alternator along with new batteries.
People need to realize that a new battery WILL NOT give you more power to use when you are driving.. The battery is used to start your car and used when your car is not started and you are listening to music and have the AC on. The only thing that a new battery will do for you is get you longer listening when you do not have you car started. If you need more power while you are driving you need a new alternator not a new battery.
incorrect.
i had 2 batts on my pair of amps and my voltage dropped below 9v
now i have 7 and it stays at 12.4 at full tilt
ok tht is all dandy but will 750 sound any diff then 500. Ha sry i jus need an answer.
depends on alot of factors, but generally not too much double the power will gain you a max of 3 db which is considered noticeably louder to the ear.
In terms of wattage it is only a 1.76 dB gain. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
NOTE THAT IS NOT ACOUSTICAL OUTPUT... THAT IS WATTAGE.
you know, 10Log(750/500)
dpu2014
dpu2014
Indianapolis
helotaxi
