$500 MISTAKE?!?! Great Amps, Blown Subs!?
Put the subs on the floor, yes, still working on a platform. But the gains are lower. I got it installed by a guy who has 5 dB drag championships, he said they should be fine as long as I keep them low. I guess he and I didnt have the same low in mind. Whine all you want, I just need to know how to test blown woofers.
Here is your setup right? You may actually have debris inside your box.
Or an unwound coil. Do you know the tuning of that box and what your sff
is set to? That's a lot of power if your feeding a signal under box tune.
I think your issue may have come from having 6K on a pair of subs that take 750 rms each. here's some specs on your subs
750 Watts RMS 1500 Walls Peak Power
XMax 1.25-Inch, 27.94 mm
2" voice coil, aluminum bobin
120 Oz double stacked magnet
that will do it everytime //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
AcidikBass20
Bass Addict
AcidikBass20
South Bend, IN
AcidikBass20
