hatedonmostly
throwin' hunnits, hunnits
So last weekend, I finished the blowthrough in my truck. I was running only two of four subs for a while since I had a sub that blew. When I had the two installed, the SQ was incredible, the response was near flat and played down to the mid 20's to the 60's no problem at all.
Now that I have all four subs installed, the high end (50+) sounds like ***. The lows are killer, but it sounds so horrible that I can't listen to anything that has notes that high. I don't know why adding two subs would do that.
However, here's the part that has me baffled the most. When playing low notes, the subs move normally and have plenty of excursion. When playing the higher notes, the subs appear to be out of phase, instead of going out, they go in. //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
The subs are RE Audio RE 12's, which have a "optimal" ported box size of 1.5 cubes @ 35. Each of my subs have 1.5 cubes and the enclosure is tuned to 33. I don't see why the box would be too big, or the tuning would be too low to have such a negative affect.
Amp settings are:
SSF set to ~20 Hz
LPF set to ~80 Hz
I shouldn't have to tell you guys that I have the gain set correctly and the bass boost off. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
This one has got me pretty baffled. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Amp settings are:
SSF set to ~20 Hz
LPF set to ~80 Hz
