5 or 6 channel amp what's good
I still have that Elemental Designs Nine-5 sitting that is a great amp if interested.Pretty clean and I have a Bass knob for it from a Nine-1.Boomin_tahoe placed some pics of it a few weeks back for me on here( I thank you sir)//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
This amp is almost 2ft in length!!
Audiobaun, you have a set price for it?
The only negative I can see for the massive audio it does not have sub woofer volume control and I know I didn't think of that till I started doing more research.
Excellent amps. U could do the 850.5 I was thinking you would want as much subwoofer power as possible. The 1200.6 will give u 600 watts when u bridge channels 5 & 6.
I know it's been a couple of months since someone last posted on this thread, but if your putting an amp on a boat it had better be marine grade. If you don't get a marine grade amp, you may be looking at lots of issues. I'd look at the marine grade version of the MMATS HIFI6150D. Gobs of power and internals (from what I can tell) seem to be top notch.
352
470
10
848
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
887
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
robdwny
robdwny
Buffalo,NY
BOOMINGRANDPA
