5 channel amps?
Tehgregzor
Enjoys loud noises.
Are there really any great 5 channel amps? Something that could put out at least 100 watts RMS @4ohms x4 channels, as well as a good wattage for a sub, at least 500 watts RMS into 4 or 2ohms. Just for simplicity's sake. I kinda realized 1000 watts is probably too much for the kind of sub i can fit into my single cab S10. But, if there isn't a high quality option for a 5 chan then i don't mind doing all the work. I'm not lazy, but i try to live my life by Occam's Razor.
Memphis Belles are usually recommended. Also check out the Kicker ZX700.5; the birth sheets are usually around 940 watts. Equates to roughly 100x4 @ 4ohm + 500x1 @ 2ohm.
a Soundstream Reference 705 would work nicely for your setup, kinda hard to find one. GL!
Thanks alot you guys, i'm going to look into the memphis. I used to own memphis subs and an amp, they were some hard hitting bastards for only being 10's.
Tehgregzor
Enjoys loud noises.
Tehgregzor
Murray,KY
Tehgregzor
