Hi guys.
I plan on building two bill fitzmaurice truck tuba's for the back of my Ford van. I already have two, 4-ohm MCM 55-2421's recommended for his Truck Tuba's, but might upgrade them in the future.
I'm unsure on the best way to wire these, or what amp I should consider using/looking for.
What confuses me is that when the MCM 55-2421's are used in the truck tuba's horns, 5 ohms actual impedance will be seen because of the folded horn design. So I'm guessing the best way to wire both, would be in parallel.. Giving me a 2.5Ω load?
And since the MCM 55-2421 are rated 240W RMS peak.. Do I need a amp rated at least 500 watts at 2Ω? Or should I go higher watts if I plan, or am forced to replace the MCM 55-2421's?
Thanks!
Thanks!
