5.5 cf tuned to 30hz
would it be ok to use 6" PVC instead of "aero's".. because I could probably get those faster and cheaper locally...
maybe i could make my own flares for the ends inside the box.
the only issue i see is cutting a perfect 6" hole for the tube.. i only have a jigsaw to cut circles.
Go very slow with the jigsaw. Make sure that you keep turning your jigsaw constantly. If you stop turning it, then you ****ed up. This is where I see alot of people not make perfect cuts. I can make a pretty **** perfect circle cut with a jig, but it is a little tedious.
01 S 10
LOUD
01 S 10
Central Florida
01 S 10
michigan born
    May 14, 2026
michigan born
    May 14, 2026
