4th order confirmation
I designed a 4th order for two 15s and went with a 3:1 ratio.
I'm working with 6ft3 sealed and 18ftft3 ported. My main question is about port area, I originally was going with 15sqin for ever cubic foot of ported section, but then saw someone mention something about the port needing to be half of the cone area?
Much appreciated if someone could help clear this up for me. I have searched the question and that seem to confuse me more.
3:1 ratio will, 9 out of 10 times do better numbers at the expense of a flatter response to say a 2:1 ratio. Usually anything under a 2:1 isn't worth doing because the small amount of gain you get isn't worth the size of the enclosure required. Half of cone area is a good place to start your tuning. Tune between 45-48 hz. If you have a meter you can then start shrinking port area until you stop gaining. Or if you aren't specifically going for numbers and like how it plays as is just leave it.
If you want to spend as much, if not more time tuning, as you did actually building the enclosure. Worth it number and bandwidth wise, yes if tuned properly. Worth it to me personally, time and hassle wise, no.
They arent stupid hard. It takes a little time but they are definitally louorder than 4th order.
Start big and tuned low..
MitchellQ
MitchellQ
Houston, texas
Papermaker85
