4AWG big enough for 900w total?
current draw over the length of the cable is the thing. Bigger wire will do nothing to create headroom- the amp gains do that. You can run a 2 ft length of 1/0 to a 75w x 2 amp, and it will still have no headroom with the gains improperly set.
What kind of alt? I have a 95 Civic with 1.6L engine. I was about to do the big 3 but the stock wires look as big as 4ga, maybe a little bigger.
The alt wire on that civic is like 8ga. The big wire you see going to the positive battery post, is the starter wire.
The amp is a DA D5600.2 and maybe a JBL BP600.1. Im still looking for a woofer amp. The run itself is maybe 13-15 feet. Car is a 95 Civic and the battery is right up against the firewall on the passenger side.
My estimate comes with a solid 18 years of installation background. Good to see that a website link agrees with me.
Of course they want you to go overkill on wiring. //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
1/0 for 510w at 16'??? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Any answer is meaningless without knowing the length of the cable as well as the power draw (for greater accuracy, don't forget to account for efficiency losses, i.e., class A, Class A/B, class D, etc.)
It's CAR audio - I think we can make a few reasonable assumptions.
1 - the wire's not going to be ridiculously long - 12-16'. Since we now know it's a Civic it may even be 10-12'. 2 - amp efficiencies aren't that different at high demand which is the only time they will even begin to tax the capacity of the power wire.
4 ga is more than enough for 900w. That is a fact.
Would 1/0 work? Of course, but it's a long way from a requirement.
johnson
johnson
Kansas City, MO
candyman206
