4 subs... 1 working harder?!?1 WTF!?!?!!
Indeed, bet that made a small difference //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I was wondering why I was getting a load of 2, without power, on the voltmeter.
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
hook up a multi meter to your power and ground wires going to your amp and blast on it for a bit and watch how low the voltage goes... maybe you just dont have enough juice for that one amp //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I get drops down to 10v. MAJOR current draw. Could a bad ground potentially be killing me also?
that happened in my buddys yukon bad ground or not enough of one so we now have 4 0g grounds straight to the frame and all is well
considering the yukon is the same as a tahoe... where did you ground the amp? I NEED a solid ground back there. I cant find one at all. Learned the hard way and drilled into the ****ing gas tank!!
i'd check the imp. load for each sub, odds are there is a shorted out wire or a loose connection somewhere... but check each subs imp. when they are disconnected from one another.. cause if one is wrong they all will be...
well the amps are right by the tailgate so i drilled a hole under the carpeting close to where the jack is on the drivers side put a grommet there and drilled 4 wholes in the frame and ran one run of 0g to each bolt
theres the little plastic strip across the back just pop that up and go at it
OoMesKoO
Me > Newbs. :fyi:
OoMesKoO
Rhode Island
audioholic
