4 or 5 channel amp for the boat??
If they are in deed the same amp I would have no problem recommending it then. Remember your beloved hertz has a version of this amp.also. hdp5 I believe. I have an nvx version of the amp I picked up on the cheap.over 2.years ago and have enjoyed it quite a bit.
You're arguing with someone who won't change his mind about Epsilon products. The Precision Power Phantom track record is meaningless to him.
Welp, in terms of impedance, I can wire the sub to present a 2ohm load by wiring the coils in parallel, or I can present a 8ohm load by wiring in series, right? They are dual 4ohm coils. Same with my mains (Polk MM651UM's x4). I have them wired in parallel 2ohm load for each channel. Channel A runs two MM651UM's (right) and Channel B runs two MM651UM's (left). I bridged channels C and D for the sub (2ohm). The system ran GREAT for two years; loud, tight, sounded fantastic... but I'm pretty sure the amp failed due to heat. It ran pretty hot, and was in a locker (Closet) below decks.
My feeling is if I had five channels, it would run cooler. On the other hand, I'm running a 1ohm load on a Polk monoblock in my truck and it runs cool and absolutely kicks *** with 2x1040DVC in a sealed Thunderform enclosure.
"Boutique" feels like another word for "never heard of it ...for a reason", though that PPI amp sounds like it would do everything I need for $200, which would be awesome. Makes me think of the old days with amps like "Targa" and "Urban Audio". :) I was planning around the $300 mark. $200 made my wife smile (trust me, audio stuff is easily the cheapest set of systems on the boat). :)
Thank you all for a ton of good advice (and offers of equipment). I've PM'd some, though the Polk MOMO amp is a single channel. Keep the idea and pointers coming!! I hope to pull the trigger tomorrow or just after Xmas.
JeffCooper
JeffCooper
Palm Harbor, FL
n2audio
