4 Ohm DVC Wiring Configurations
AlwaysFollowed
04 Silverado
Hey guys i just picked up a couple new subs and have some question. The new subs are 4 Ohm DVC's. My amp is a Premier PRS-D2000T and I was planning on running the amp bridged at 600W RMS x 1 and wiring the subs accordingly. However i was recently doing some research and found this wiring diagram for 1 4Ohm DVC sub in which it can be wired for a 2 ohm load.
http://www.crutchfieldadvisor.com/le...pedance=DVC4x2
My amp will do 300W RMS x 2 a 2 ohms. Question being which is the better way to wire my subs in relation to my amp. Should i bridge the amp or run it using the 2 channels separately and wiring each sub to achieve a 2 ohm load? or does it matter? Thanks.
Yes, do that
AlwaysFollowed
04 Silverado
AlwaysFollowed
Niagara Falls, Ontario
AlwaysFollowed
