4 Channel Amp vs. 2 Channel + Monoamp
Rhythm
I was thinking of buying a pair of front mids and leaving the rear stock. I also wanted to add a 10" or 12" for the woofer.
Would it be better to have a dedicated 2 channel amp for the front and a monoamp for the sub OR have a 4 channel amp for all of them?
Any input?
You could get it done with a good 4 channel, and there'd be little, if anything given up by doing it.
Plus it would be cheaper, and the installation would be more straightforward.
The one drawback I can think of is future upgrades would be a lot less convenient.
You could get it done with a good 4 channel, and there'd be little, if anything given up by doing it.Plus it would be cheaper, and the installation would be more straightforward.
or if the amp goes bad the whole system is gone
you can always use this 4 channel to power 4 doors for future upgrade and get a more decent sub amp and upgrade sub
best to get amp 25% to 30% more power than sub rms since your eletrical most likley is not 14.4 so most amp will run lower than spec. Sub can take a little more if your amp puts out spec wattage.
Rhythm
Rhythm
Chicago burbs, IL
denim
