4 channel amp switch question..
jbgarner12
I recently purchased a 32440 Eclipse 4 channel amp for my mids/tweets...On this amp it has of course high pass/low pass switches and it also has L+R/Stereo/Mono?..Now I know what the mono would be for, but what do you guy's use for a four speaker set up? Right now I have it on L+R..I'm sorta a noob so I'm confused on which it should be on...
Speakers are 4 Boston Acoustics SL80
» 2-way plate speakers for 5"x7"
» copolymer woofer with rubber surround
» 1" Kortec® dome tweeter
» power range: 2-60 watts RMS (200 watts peak power)
» frequency response 45-20,000 Hz
» sensitivity: 90 dB
Eclipse 32240 specs
200W x 4 Channel Max. Power Output at 2Stereo
120W x 4 Channel 0.1% THD at 2Stereo, 20-20,000Hz@13.8V (RMS Continuous Power)
85W x 4 Channel 0.1% THD at 4W Stereo, 20-20,000Hz@13.8V (RMS Continuous Power)
You want it set to stereo.
L+R I would assume is summing the the inputs (left plus right). So, each amplifier channel is outputting both the left signal AND the right signal...effectively killing "stereo" sound.
jbgarner12
jbgarner12
COLORADO
jbgarner12
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
