Sold 4 channel amp $80 + shipping and 2 door speakers $40 + shipp super cheap make an offe
cthedinger
2 of the speakers
Pioneer Premier TS-A702C components
$40 plus shipping
6-3/4" (oversized 6-1/2") A-Series Component System
Power Handling:
Peak: 460 watts per set / 230 watts each side
RMS: 100 watts per set / 50 watts each side
Composite injection molded polypropylene cone with interlaced Aramid Fiber woofer
Butyl rubber surround
7/8" Tetron Soft dome tweeter with magnetic fluid and neodymium magnet
2-Way external crossovers with low pass and high pass filter at 12 dB/octave
Surface, flush, or invisible tweeter mounting
Aramid fiber damper
Glass-Imide voice coil bobbin
4 ohms impedance
OFC Copper voice coil wire
Top-mount depth: 2-1/2"
there was a little damage on one of the door speakers i have fixed it and it still sounds great but it isnt the prettiest thing
The amp
Pioneer GM-6400F 4 Channel 600 Watts Car Amplifier
$80 plus shipping
•GM Series 4-Channel Class AB Car Amplifier
•RMS Power Rating:
◦4 ohms: 60 watts x 4 chan.
◦2 ohms: 75 watts x 4 chan.
◦Bridged, 4 ohms: 150 watts x 2 chan.
•Max power output: 600 watts
•PWM Regulated MOSFET power supply
•LED power indicators
•4/3/2 channel operation
•Built-in crossover LPF/HPF (front/rear independent)
•Variable high-pass filter (cut off frequency: 80 Hz, -12 dB/octave)
•Variable low-pass filter (cut off frequency: 80 Hz, -12 dB/octave)
•Built-in speaker level inputs
•Hi-volt (400mV ~ 6.5v) input level control
•Exclusive H shaped chassis and heatsink
•Gain control caution feature helps prevent damage to speakers
•CEA-2006 compliant amplifier
•Frequency response: 10-50,000 Hz
•Dimensions: 8-1/2"L x 2-1/2"W x 13-5/8"H
everything has only been used for about two weeks have the boxes for everything but one pair of speakers
i am selling this stuff because i am picking up a chrystler new yorker this week :yahoo: and decided to go with a whole different set up
will have more pictures up soon
cthedinger
cthedinger
Inglewood, CA
cthedinger
