Sold FS: 12" RE Sx d2
Tone415
A.K.A FrisnoG
$140 shipped
its the one without the recone
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 1000 W
Force Factor -Bl: 21
Electrical Q Value -Qes: .32
Mechanical Q Value -Qms: 4.4
Total Speaker Q Value -Qts: .30
Free Air Resonance -Fs: 30.6 Hz
Equivalent Compliance -Vas: 47.6 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency - SPL 1W/1m: 88.1 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 1.9 ohm
Mounting Depth - 6.5”
Mounting Hole Diameter - 11”
Overall Diameter - 12.5”
Bolt Hole Circle - 11.75”
Motor Width - 6.5”
Motor Depth - 3.25”
Basket Depth - 3.25”
Displacement - .16 cu. ft.
Weight - 24 lbs.
Dual Composite 2-piece Cone
Rubbertek Foam Surround
Cast Aluminum Basket
Tork-Tite Terminal
3 " 8-layer Aluminum Voice Coil
FEA Optimized Motor Structure
Triple Stack Maganets
Progressive Spiders
Wrap around Rubber Gasket
Tone415
A.K.A FrisnoG
Tone415
San Francisco, CA
hilodaze
