4 4ch. amps!
Beerdrnkr
(2) Audiopipe AQX-360.4's
MTX XThunder 504x
MB Quart DSC-4125
(Audiopipe) AQX Elite MOSFET amplifier series have been tested and proven to deliver
the best power, performance and durability whether you're competing or just
cruising down on the strip. Its bold body is constructed of a special cast
aluminum material which maximizes the dissipation of heat. Maintaining
optimum performance under severe conditions and a nonstop flow of extre-
me power is what you get when you opt for an AQX Elite MOSFET amplifier.
Features:
Overload Protection - Variable Subsonic Filter
Built-in Variable Phase Shift
• Power Amplifier: 2500 Watts
• Channel: 4 Channels Class AB
• Frequency Response: 20Hz - 30KHz
• Bass Boost: 0-15dB @ 45Hz
• Input Level: 0.2-6V
• Crossover Range: 55Hz - 550Hz
• THD:
• Output Power (RMS):
4 Channel @ 4Ω - 125W
4 Channel @ 2Ω - 180W
2 Channel @ 4Ω - 360W
• Dimension: 433x182x66mm
(MTX) X Thunder Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 50 watts x 4 chan.
2 ohms: 75 watts x 4 chan.
Bridged, 4 ohms: 150 watts x 2 chan.
Patented Adaptive Class AB Technology
LED power indicator
Anodized Finish
Single channel operation
Chrome X Thunder Badge
Stereo gain control
Heavy duty aluminum construction with large heat-sinks
Variable high-pass filter (40-8000 Hz, 12 dB/octave)
Variable low-pass filter (40-800 Hz, 24 dB/octave)
Frequency response: 20-20000 Hz
Dimensions: 12-1/2" L x 9-1/8" W x 2-1/4" H
Discus Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 125 watts x 4 chan.
2 ohms: 250 watts x 4 chan.
Bridged, 4 ohms: 500 watts x 2 chan.
PWM (Pulse Width Modulated) MOSFET power supply
Remote bass level input (remote level control sold separately)
LED power and protection indicators
Tuned Bass EQ (0-9 dB bass boost at 45 Hz)
Bridgeable operation
Soft start sound
Preamp RCA outputs
DC, short, thermal, and overload protection circuitry
Unbalanced RCA inputs
Switchable 2-channel/4-channel input modes
Damping Factor: >180
Variable input level control: 0.2V-0.6V
Variable high-pass filter (10-1200 Hz, 24 dB/octave)
Variable low-pass filter (30-150 Hz, 24 dB/octave)
Frequency response: 10-20000 Hz
Dimensions: 15.75"L x 9.45"W x 2.7H
$125 shipped each (Audiopipe)
$90 shipped (MTX)
$140 shipped (MB Quart)
(Audiopipes) They are currently installed that's why I couldn't take the best pics of them but they're in perfect condition and have been barely used. 100% functional and I've had some great amps in the past and these are surprisingly good. Honestly, I was surprised.
(MTX) In great condition and 100% functional, I use it as a tweeter amp and it worked very well for that. It can be crossed over up to 8khz.
(MB Quart) Amps in decent cosmetic shape, I would say 6/10 or so. One of the metals rings around one of the RCA inputs comes out a little easy and is a little bent but the amp is still 100% functional and delivers a ton of power.
Back up, I can ship out tomorrow. These amps provide good clean power, just ask imtjnotu and zeuslicious on here they've heard it powering my 3 way frontstage.
Beerdrnkr
Beerdrnkr
San Diego
Beerdrnkr
