4.4 @ 32 worklog
Lil_KB
this is going on the back floor of an extended cab chevy...
sub is a 15" Fi BTL.
credit to iam3amppimp for help with the design and he is making and sending me some rings to mount the sub on to acquire proper mounting depth.
initial sketch:
hump in the floor ftl...
progress today:
plenty more cutting to do....
stay tuned.
how does that laser help? does it really work?
when you're freehanding it does actually help a good bit...but when you're using the method i am here, i just used it to line up the saw with the line to make sure it was correct basicly.
Thats a real cool design. I also have an extended cab chevy, so I know how much of a PITA it is to work around that hump. Wont have to worry about it with the next box, cause it will all be fiberglass //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
baasdhjasdksdf.
slowly but surely coming along....only get an hour or two a day now...daylight savings ftl.
Damn. You have that set way too low man. The blade should only go past the wood by about 1/4". Adjust that bad boy.
Lil_KB
Lil_KB
Louisiana
crazy4ozs
